주요 콘텐츠로 건너뛰기
Lenovo IdeaPad N586 Motherboard Replacement
필요한 것
  1. Lenovo IdeaPad N586 Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Lenovo IdeaPad N586 Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
  2. Lenovo IdeaPad N586 Motherboard Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad N586 Motherboard Replacement: 2 단계, 이미지 2/2
    • Now push the right clip to the right and hold it while using your other hand to pull the battery out.
  3. Lenovo IdeaPad N586 Motherboard Replacement, Back Panel: 3 단계, 이미지 1/1
    • Remove the two screws highlighted.
  4. Lenovo IdeaPad N586 Motherboard Replacement: 4 단계, 이미지 1/1
    • This is the back of the laptop with the cover removed.
  5. Lenovo IdeaPad N586 Motherboard Replacement, Optical Drive: 5 단계, 이미지 1/1
    • Locate and remove the single screw right of the optical drive
  6. Lenovo IdeaPad N586 Motherboard Replacement: 6 단계, 이미지 1/1
    • Optical Drive should slide out easily with one thumb's effort.
  7. Lenovo IdeaPad N586 Motherboard Replacement, Hard Drive: 7 단계, 이미지 1/1
    • Now remove the last two screws highlighted
  8. Lenovo IdeaPad N586 Motherboard Replacement: 8 단계, 이미지 1/2 Lenovo IdeaPad N586 Motherboard Replacement: 8 단계, 이미지 2/2
    • Push hard drive away from the center of the chassis.
    • Lift the hard drive out of the chassis using the tab located on the drive.
  9. Lenovo IdeaPad N586 Motherboard Replacement, Wifi card: 9 단계, 이미지 1/2 Lenovo IdeaPad N586 Motherboard Replacement, Wifi card: 9 단계, 이미지 2/2
    • Remove the white and black wires.
  10. Lenovo IdeaPad N586 Motherboard Replacement: 10 단계, 이미지 1/2 Lenovo IdeaPad N586 Motherboard Replacement: 10 단계, 이미지 2/2
    • Next, unscrew the wifi card
  11. Lenovo IdeaPad N586 Motherboard Replacement: 11 단계, 이미지 1/1
    • Pull out the wifi card.
  12. Lenovo IdeaPad N586 Motherboard Replacement, Memory: 12 단계, 이미지 1/2 Lenovo IdeaPad N586 Motherboard Replacement, Memory: 12 단계, 이미지 2/2
    • Now push the little clips out away from the memory to unlock the memory.
  13. Lenovo IdeaPad N586 Motherboard Replacement: 13 단계, 이미지 1/1
    • After unlocking the memory from it's position, pull the memory out.
  14. Lenovo IdeaPad N586 Motherboard Replacement, Keyboard: 14 단계, 이미지 1/1
    • Remove three screws on bottom of case. They have a little keyboard image next to them. If you don't do this first, the keyboard will not come off. Place the plastic spudger right under the edge of the keyboard and lift up the keyboard.
  15. Lenovo IdeaPad N586 Motherboard Replacement: 15 단계, 이미지 1/1
    • Slowly and gently lift the keyboard up to separate from the chassis.
  16. Lenovo IdeaPad N586 Motherboard Replacement: 16 단계, 이미지 1/1
    • Gently lift the keyboard off the chassis.
    • Carefully disconnect the keyboard from the laptop by unhooking the keyboard ribbon.
  17. Lenovo IdeaPad N586 Motherboard Replacement: 17 단계, 이미지 1/1
    • Now remove the keyboard from the computer.
  18. Lenovo IdeaPad N586 Motherboard Replacement, Fan: 18 단계, 이미지 1/2 Lenovo IdeaPad N586 Motherboard Replacement, Fan: 18 단계, 이미지 2/2
    • Pull the plug shown.
  19. Lenovo IdeaPad N586 Motherboard Replacement: 19 단계, 이미지 1/2 Lenovo IdeaPad N586 Motherboard Replacement: 19 단계, 이미지 2/2
    • Lift up fan.
    • Remove two highlighted screws.
  20. Lenovo IdeaPad N586 Motherboard Replacement: 20 단계, 이미지 1/1
    • This is the fan separated from the motherboard.
  21. Lenovo IdeaPad N586 Motherboard Replacement, Motherboard: 21 단계, 이미지 1/1
    • Remove all screws shown.
  22. Lenovo IdeaPad N586 Motherboard Replacement: 22 단계, 이미지 1/1
    • Flip laptop over.
  23. Lenovo IdeaPad N586 Motherboard Replacement: 23 단계, 이미지 1/1
    • Remove one more screw hidden under white paper oval sticker (lenovo)
  24. Lenovo IdeaPad N586 Motherboard Replacement: 24 단계, 이미지 1/1
    • Remove keyboard bezel.
  25. Lenovo IdeaPad N586 Motherboard Replacement: 25 단계, 이미지 1/2 Lenovo IdeaPad N586 Motherboard Replacement: 25 단계, 이미지 2/2
    • Unplug highlighted tabs.
  26. Lenovo IdeaPad N586 Motherboard Replacement: 26 단계, 이미지 1/2 Lenovo IdeaPad N586 Motherboard Replacement: 26 단계, 이미지 2/2
    • More tabs need to be removed.
  27. Lenovo IdeaPad N586 Motherboard Replacement: 27 단계, 이미지 1/2 Lenovo IdeaPad N586 Motherboard Replacement: 27 단계, 이미지 2/2
    • Remove final plug connecting motherboard to base of laptop.
  28. Lenovo IdeaPad N586 Motherboard Replacement: 28 단계, 이미지 1/1
    • This is what the motherboard looks when taken out of the laptop.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Patrick
회원 가입일: 04/08/14
453 평판
안내서 3개 작성하였습니다
Cal Poly, Team 8-7, Regan Spring 2014 Cal Poly, Team 8-7, Regan Spring 2014 회원
CPSU-REGAN-S14S8G7
5 회원들
안내서 10개 작성하였습니다
댓글 2개
You cannot must pull up on the keyboard. There are three screws on the bottom of the case that have to be removed first!!
Clint Hatchett - 답글
My laptop open hoi no please tell me why open hoi na please vaia
Mdimranh203@gmail.com - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 2,140
