주요 콘텐츠로 건너뛰기
Lenovo IdeaPad N586 Optical Drive Replacement
필요한 것
  1. Lenovo IdeaPad N586 Optical Drive Replacement, Battery: 1 단계, 이미지 1/2 Lenovo IdeaPad N586 Optical Drive Replacement, Battery: 1 단계, 이미지 2/2
    • To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
  2. Lenovo IdeaPad N586 Optical Drive Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad N586 Optical Drive Replacement: 2 단계, 이미지 2/2
    • Now push the right clip to the right and hold it while using your other hand to pull the battery out.
  3. Lenovo IdeaPad N586 Optical Drive Replacement, Back Panel: 3 단계, 이미지 1/1
    • Remove the two screws highlighted.
  4. Lenovo IdeaPad N586 Optical Drive Replacement: 4 단계, 이미지 1/1
    • This is the back of the laptop with the cover removed.
  5. Lenovo IdeaPad N586 Optical Drive Replacement, Optical Drive: 5 단계, 이미지 1/1
    • Locate and remove the single screw right of the optical drive
  6. Lenovo IdeaPad N586 Optical Drive Replacement: 6 단계, 이미지 1/1
    • Optical Drive should slide out easily with one thumb's effort.
결론
Christopher
회원 가입일: 04/08/14
676 평판
안내서 6개 작성하였습니다
Cal Poly, Team 8-7, Regan Spring 2014 Cal Poly, Team 8-7, Regan Spring 2014 회원
CPSU-REGAN-S14S8G7
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 344
