소개
This guide will provide instructions to remove the bottom case of the laptop. This is the first step in replacing most of the parts in this computer.
부품
부품은 필요하지 않습니다.
  1. Turn off laptop before beginning.
    • Turn off laptop before beginning.
    • Remove the five 5.0 mm Phillips #0 screws marked in this picture.
  2. Use the spudger to separate the bottom panel from the laptop case.
    • Use the spudger to separate the bottom panel from the laptop case.
    • It is recommended that you start from a corner and work your way around the panel.
    • Be careful not to bend or break the bottom panel.
    • Lift up the right side of the case as shown, and slide it to the left to detach the case.
    • The disk drive will remain attached to the bottom panel. Sliding the panel to the left disconnects it.
    • To avoid damaging the disk drive connector, avoid lifting the right side of the panel too far up.
결론
Joel Hottman
회원 가입일: 2018년 09월 28일
277 평판
안내서 3개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 41
전체 시간: 67
