소개
Upgrading the hard drive is a common way to increase the performance and reliability of your device. This guide provides instructions on how to accomplish this.
부품
부품은 필요하지 않습니다.
  1. Turn off laptop before beginning.
    • Turn off laptop before beginning.
    • Remove the five 5.0 mm Phillips #0 screws marked in this picture.
  2. Use the spudger to separate the bottom panel from the laptop case.
    • Use the spudger to separate the bottom panel from the laptop case.
    • It is recommended that you start from a corner and work your way around the panel.
    • Be careful not to bend or break the bottom panel.
    • Lift up the right side of the case as shown, and slide it to the left to detach the case.
    • The disk drive will remain attached to the bottom panel. Sliding the panel to the left disconnects it.
    • To avoid damaging the disk drive connector, avoid lifting the right side of the panel too far up.
    • Remove the two 2.5mm Phillips #0 screws marked in this picture.
    • Locate the battery connector.
    • Using the pointy end of the spudger, press down on the middle tab of the connector to release the retaining clip.
    • Work each side of the connector out until it comes completely out. Pull it free of the connector housing.
    • There is still a live current in the battery. Use a plastic tool to pull the battery connector.
    • The battery can now be lifted from the laptop case.
    • Remove the two 5.0mm Phillips #0 screws retaining the hard drive.
    • Lift up on the left side of the hard drive and pull to the left to remove the hard drive from the laptop.
    • To prevent damage to the connector, do not lift up too far on the hard drive.
결론
Jack Markee
회원 가입일: 2018년 09월 28일
317 평판
안내서 2개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 65
전체 시간: 91
