주요 콘텐츠로 건너뛰기
Lenovo IdeaPad S10-2 Hard Drive Replacement
필요한 것
  1. Lenovo IdeaPad S10-2 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/2 Lenovo IdeaPad S10-2 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Start with laptop closed.
    • Turn laptop over so the back panel is visible, as shown in the second image.
    • Remove the two 40 mm Phillips screws using a Phillips J0 head screwdriver.
  2. Lenovo IdeaPad S10-2 Hard Drive Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad S10-2 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Remove both 40 mm Phillips screws using a Phillips J0 head screwdriver.
    • Remove the back panel and set it aside.
  3. Lenovo IdeaPad S10-2 Hard Drive Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad S10-2 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Remove the 40 mm screw using a Phillips J0 head screwdriver.
  4. Lenovo IdeaPad S10-2 Hard Drive Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad S10-2 Hard Drive Replacement: 4 단계, 이미지 2/2
    • After removing the screw, carefully wedge the flat end of a spudger in the spacing to remove the hard drive from the port.
    • Pry the hard drive out of its port.
    • Push the wedged end of the spudger out as indicated by the action shots.
  5. Lenovo IdeaPad S10-2 Hard Drive Replacement: 5 단계, 이미지 1/2 Lenovo IdeaPad S10-2 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Carefully lift the hard drive enclosure to remove it from the laptop.
    • The enclosure is the metal case holding the actual hard drive. You must remove the metal case in order to replace the hard drive.
  6. Lenovo IdeaPad S10-2 Hard Drive Replacement: 6 단계, 이미지 1/3 Lenovo IdeaPad S10-2 Hard Drive Replacement: 6 단계, 이미지 2/3 Lenovo IdeaPad S10-2 Hard Drive Replacement: 6 단계, 이미지 3/3
    • The hard drive enclosure has four 40 mm screws keeping the hard drive in place.
    • Remove the four 40 mm screws with a Phillips J0 head screwdriver.
  7. Lenovo IdeaPad S10-2 Hard Drive Replacement: 7 단계, 이미지 1/2 Lenovo IdeaPad S10-2 Hard Drive Replacement: 7 단계, 이미지 2/2
    • Slide the hard drive out of the enclosure.
    • The new hard drive can be inserted into the same enclosure.
결론
Anthony
회원 가입일: 10/13/15
258 평판
안내서 2개 작성하였습니다
Sam Houston State, Team 1-7, Blackburne Fall 2015 Sam Houston State, Team 1-7, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S1G7
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 24
전체 시간: 9,500
