주요 콘텐츠로 건너뛰기
Lenovo IdeaPad S10-2 Key Replacement
필요한 것
  1. Lenovo IdeaPad S10-2 Key Replacement, Key: 1 단계, 이미지 1/1
    • Open the laptop so the keyboard is facing you.
  2. Lenovo IdeaPad S10-2 Key Replacement: 2 단계, 이미지 1/1
    • Use a spudger to remove the keys by wedging it underneath the key.
  3. Lenovo IdeaPad S10-2 Key Replacement: 3 단계, 이미지 1/1
    • Pull back the key to remove and separate the key from the metal bars underneath.
  4. Lenovo IdeaPad S10-2 Key Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad S10-2 Key Replacement: 4 단계, 이미지 2/2
    • Ensure the bars are in correctly before continuing. The end of the top bar should be in the hooks and the end of the bottom bar should go through the loops.
    • To install the new key, make sure the top bar is attached to the bottom of the key and push down until a click is heard.
결승점
Anthony
회원 가입일: 10/13/15
258 평판
안내서 2개 작성하였습니다
Sam Houston State, Team 1-7, Blackburne Fall 2015 Sam Houston State, Team 1-7, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S1G7
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 850
