주요 콘텐츠로 건너뛰기
Lenovo IdeaPad S10-2 Keyboard Replacement
필요한 것
  1. Lenovo IdeaPad S10-2 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Rotate the laptop so the back side is facing you.
    • From this side, you should be able to see both of the gaps where the two plastic materials meet.
  2. Lenovo IdeaPad S10-2 Keyboard Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad S10-2 Keyboard Replacement: 2 단계, 이미지 2/2
    • Wedge the nylon or metal spudger inside the gap and pry open the two plastic parts.
  3. Lenovo IdeaPad S10-2 Keyboard Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad S10-2 Keyboard Replacement: 3 단계, 이미지 2/2
    • Open the laptop.
    • Place the nylon or metal spudger under the top half that is loose and pull up to pry it open.
  4. Lenovo IdeaPad S10-2 Keyboard Replacement: 4 단계, 이미지 1/3 Lenovo IdeaPad S10-2 Keyboard Replacement: 4 단계, 이미지 2/3 Lenovo IdeaPad S10-2 Keyboard Replacement: 4 단계, 이미지 3/3
    • Pull up on the loose component to remove.
    • As you lift the keyboard, you should be able to see a strip connected to the laptop.
  5. Lenovo IdeaPad S10-2 Keyboard Replacement: 5 단계, 이미지 1/3 Lenovo IdeaPad S10-2 Keyboard Replacement: 5 단계, 이미지 2/3 Lenovo IdeaPad S10-2 Keyboard Replacement: 5 단계, 이미지 3/3
    • Remove the strip by pulling both sides of the blue strip out.
    • Lift and remove the keyboard from the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mary
회원 가입일: 10/13/15
132 평판
안내서 1개 작성함
Sam Houston State, Team 1-7, Blackburne Fall 2015 Sam Houston State, Team 1-7, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S1G7
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 3,261
