소개
Replacing the keyboard on your laptop can be necessary if your keyboard is no longer responding. You will need a nylon or metal spudger. Make sure that the power is off before continuing.
필요한 것
Rotate the laptop so the back side is facing you.
From this side, you should be able to see both of the gaps where the two plastic materials meet.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
