주요 콘텐츠로 건너뛰기
Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement
필요한 것
  1. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement, Wireless WiFi Card: 1 단계, 이미지 1/1
    • The tools needed are the blunt edge of the spudger and a Phillips J0 head screwdriver.
    • Ensure your device is powered off before continuing.
  2. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: 2 단계, 이미지 2/2
    • Turn the laptop over to begin.
    • Remove the two 40 mm screws with a Phillips J0 head screwdriver.
  3. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: 3 단계, 이미지 2/2
    • The WiFi card is found near the bottom of the panel.
  4. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: 4 단계, 이미지 1/3 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: 4 단계, 이미지 2/3 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Do not use the metal precision tweezers as shown.
    • Using the blunt end of the spudger, wedge the spudger beneath the connector and pull straight up to remove the white wire. Repeat to remove the black connector.
    • When reinstalling these U.FL connectors, hold the connector in place and gently push down. The connector should snap into place like a button.
  5. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: 5 단계, 이미지 1/3 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: 5 단계, 이미지 2/3 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: 5 단계, 이미지 3/3
    • Remove the two 40 mm screws using a Phillips J0 head screwdriver.
    • Lift and remove the WiFi card.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lucy Mendez
회원 가입일: 10/10/15
152 평판
안내서 1개 작성함
Sam Houston State, Team 1-7, Blackburne Fall 2015 Sam Houston State, Team 1-7, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S1G7
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 30
전체 시간: 2,149
