소개
Use this guide to replace a faulty cooling fan of a Lenovo IdeaPad S210 Touch. Replacing the cooling fan can alleviate problems caused by overheating such as unexpected shutdowns and shortened battery life. The operation is a simple process that involves a #0 Phillips screwdriver and the removal of screws that hold the fan in place.
Before beginning the removal process, ensure your device is turned off and disconnected from power supplies.
필요한 것
Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
