소개
Replacing your speakers may be necessary if they are producing scratchy audio or none at all.
필요한 것
Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
Using a #0 Phillips screwdriver, remove the four 4mm screws that secure the hard drive bracket to the motherboard.
Remove four cables connected to motherboard by pulling gently on connector at base of cables.
거의 끝나갑니다!
결론
