주요 콘텐츠로 건너뛰기
Lenovo IdeaPad S340-15IWL Battery Replacement
필요한 것
  1. Lenovo IdeaPad S340-15IWL Battery Replacement, Back Panel: 1 단계, 이미지 1/2 Lenovo IdeaPad S340-15IWL Battery Replacement, Back Panel: 1 단계, 이미지 2/2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Battery Replacement: 2 단계, 이미지 1/1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Battery Replacement, Battery: 3 단계, 이미지 1/2 Lenovo IdeaPad S340-15IWL Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Disconnect the battery cable by gently pulling it straight out of the connector.
    • Be sure to pull parallel to the device to avoid bending the motherboard connector.
    • The battery connector does not lock and only requires light pressure to insert and remove.
    • Remove the battery from the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Luke Ruff
회원 가입일: 09/17/21
183 평판
안내서 1개 작성함
댓글 한 개
Worked wonderfully. Thanks for the great instructions.
Deb Dhar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 20
30일 전: 142
전체 시간: 5,376
