주요 콘텐츠로 건너뛰기
Lenovo IdeaPad S340-15IWL CMOS Battery Replacement
필요한 것
  1. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, Back Panel: 1 단계, 이미지 1/2 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, Back Panel: 1 단계, 이미지 2/2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement: 2 단계, 이미지 1/1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, CMOS Battery: 3 단계, 이미지 1/3 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, CMOS Battery: 3 단계, 이미지 2/3 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, CMOS Battery: 3 단계, 이미지 3/3
    • Remove the circular CMOS battery on the far left side of the computer by lifting it with your finger or an opening tool.
    • This is only attached with adhesive, so it does not require extensive force.
  4. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement: 4 단계, 이미지 2/2
    • Unplug the bundled red and black wires connecting the CMOS battery to the side of the device.
    • Remove the CMOS battery from the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kristen Gismondi
회원 가입일: 11/12/14
82,266 평판
안내서 200개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,288개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 130
전체 시간: 1,621
