주요 콘텐츠로 건너뛰기
Lenovo IdeaPad S340-15IWL Fan Replacement
필요한 것
  1. Lenovo IdeaPad S340-15IWL Fan Replacement, Back Panel: 1 단계, 이미지 1/2 Lenovo IdeaPad S340-15IWL Fan Replacement, Back Panel: 1 단계, 이미지 2/2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Fan Replacement: 2 단계, 이미지 1/1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Fan Replacement, Fan: 3 단계, 이미지 1/1
    • Remove the two 3 mm screws connecting the fan to the casing using a Phillips #0 screwdriver.
  4. Lenovo IdeaPad S340-15IWL Fan Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad S340-15IWL Fan Replacement: 4 단계, 이미지 2/2
    • Using a spudger, gently disconnect the fan's cable from the motherboard.
  5. Lenovo IdeaPad S340-15IWL Fan Replacement: 5 단계, 이미지 1/1
    • Carefully unwind the black cable that runs between the top of the battery and the bottom of the fan from the grooves along the side of the fan.
    • In order to do so, you will need to pull up the metallic tape that holds the cable in place using either your fingers or a plastic prying tool to lift up the edge.
    • If you attempt to remove the device’s fan without removing the battery, the black cable may be wedged underneath the top of the battery. In this scenario, it is recommended that you at least loosen the screws holding the battery in place to allow for the cable to be removed with less resistance.
  6. Lenovo IdeaPad S340-15IWL Fan Replacement: 6 단계, 이미지 1/3 Lenovo IdeaPad S340-15IWL Fan Replacement: 6 단계, 이미지 2/3 Lenovo IdeaPad S340-15IWL Fan Replacement: 6 단계, 이미지 3/3
    • Carefully pick up the fan by the corners and detach the small connector wire by pulling parallel to the device.
    • Remove the fan from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Christine Robbins
회원 가입일: 09/17/21
522 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 21
전체 시간: 789
