주요 콘텐츠로 건너뛰기
Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement
필요한 것
  1. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Back Panel: 1 단계, 이미지 1/2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Back Panel: 1 단계, 이미지 2/2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: 2 단계, 이미지 1/1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Wi-Fi Card: 3 단계, 이미지 1/2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Wi-Fi Card: 3 단계, 이미지 2/2
    • Pull up the black foam adhesive that covers the screw and connectors holding the Wi-Fi card in place.
  4. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: 4 단계, 이미지 2/2
    • Using an opening tool, lift up on the black and white coaxial cables on the Wi-Fi card and gently pull upward to unplug them.
    • When reconnecting the cables, be sure to match the colors to the arrows on the Wi-Fi card.
  5. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: 5 단계, 이미지 1/2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: 5 단계, 이미지 2/2
    • Remove the single 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
    • Gently lift the Wi-Fi card out of the computer.
결론
Kristen Gismondi
회원 가입일: 11/12/14
82,305 평판
안내서 200개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,301개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 39
전체 시간: 1,042
