소개
To replace the fan, follow this guide.
필요한 것
Turn your computer over so the back is face up.
Use your forefinger to unlock the two tabs located on the back. Slide the tabs until you see the red showing.
The battery cover will then pop up allowing you access to the battery.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
