주요 콘텐츠로 건너뛰기
Lenovo IdeaPad S400 Touch Speakers Replacement
필요한 것
  1. Lenovo IdeaPad S400 Touch Speakers Replacement, Battery: 1 단계, 이미지 1/3 Lenovo IdeaPad S400 Touch Speakers Replacement, Battery: 1 단계, 이미지 2/3 Lenovo IdeaPad S400 Touch Speakers Replacement, Battery: 1 단계, 이미지 3/3
    • Turn your computer over so the back is face up.
    • Use your forefinger to unlock the two tabs located on the back. Slide the tabs until you see the red showing.
    • The battery cover will then pop up allowing you access to the battery.
  2. Lenovo IdeaPad S400 Touch Speakers Replacement, Speakers: 2 단계, 이미지 1/3 Lenovo IdeaPad S400 Touch Speakers Replacement, Speakers: 2 단계, 이미지 2/3 Lenovo IdeaPad S400 Touch Speakers Replacement, Speakers: 2 단계, 이미지 3/3
    • Remove the five 6mm Phillips #0 screws from the back panel.
    • Pull back the rubber tabs from the corners of the laptop backing to expose the screws.
    • The two tabs next to battery flip toward the battery. The two remaining tabs flip down, away from the battery.
    • Remove the four 4mm Phillips #0 screws that are underneath the rubber tabs.
    • Remove the three 6mm Phillips #0 screws from under the battery.
  3. Lenovo IdeaPad S400 Touch Speakers Replacement: 3 단계, 이미지 1/1
    • Slide the back panel away to remove it.
    • Don't be afraid to apply force when removing the back panel.
  4. Lenovo IdeaPad S400 Touch Speakers Replacement: 4 단계, 이미지 1/3 Lenovo IdeaPad S400 Touch Speakers Replacement: 4 단계, 이미지 2/3 Lenovo IdeaPad S400 Touch Speakers Replacement: 4 단계, 이미지 3/3
    • Remove the two 2mm Phillips #0 screws from each speaker.
    • Take the speakers off the base.
    • Pull the connecting cable from the motherboard, which will release the speakers.
    • To install the replacement speakers, follow these steps in reverse order.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Max Hoyle
회원 가입일: 02/12/19
529 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 165
