주요 콘텐츠로 건너뛰기
Lenovo IdeaPad U310 Fan Replacement
필요한 것
  1. Lenovo IdeaPad U310 Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the device over so the bottom panel is facing up.
    • Remove the rubber feet by pinching and pulling in an upward motion.
    • The rubber feet are missing from this photo, but will be located within the red markups.
  2. Lenovo IdeaPad U310 Fan Replacement: 2 단계, 이미지 1/1
    • Remove the 4 screws securing the bottom panel to the device.
    • The screws are missing from this device and are not pictured. They will be located under the rubber feet within the red markups.
  3. Lenovo IdeaPad U310 Fan Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad U310 Fan Replacement: 3 단계, 이미지 2/2
    • Place the plastic opening tool between the bottom panel and device.
    • Pry around the device's outer edge until the bottom panel is no longer attached.
    • Lift the bottom panel up and away from device.
  4. Lenovo IdeaPad U310 Fan Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad U310 Fan Replacement: 4 단계, 이미지 2/2
    • Unplug the Battery from the circuit board by carefully prying the connector from its housing.
  5. Lenovo IdeaPad U310 Fan Replacement: 5 단계, 이미지 1/2 Lenovo IdeaPad U310 Fan Replacement: 5 단계, 이미지 2/2
    • Remove the 5.6 mm Screw with the PH1 screwdriver.
    • Remove the 4.6 mm screws with the PH1 screwdriver.
  6. Lenovo IdeaPad U310 Fan Replacement: 6 단계, 이미지 1/2 Lenovo IdeaPad U310 Fan Replacement: 6 단계, 이미지 2/2
    • Lift the strip tape away from the battery, being careful not to completely remove it.
  7. Lenovo IdeaPad U310 Fan Replacement: 7 단계, 이미지 1/1
    • Remove the battery by lifting up and away from device.
  8. Lenovo IdeaPad U310 Fan Replacement, Fan: 8 단계, 이미지 1/2 Lenovo IdeaPad U310 Fan Replacement, Fan: 8 단계, 이미지 2/2
    • Unplug fan by pinching the connector and pulling it away from its housing.
  9. Lenovo IdeaPad U310 Fan Replacement: 9 단계, 이미지 1/2 Lenovo IdeaPad U310 Fan Replacement: 9 단계, 이미지 2/2
    • Unscrew 5.1 mm screw using PH1.
    • Unscrew the four 3.6 mm screws using PH1.
    • Theses five screws are attached to the black plate with rubber stoppers. You will be able to loosen them from the circuit board, but they will stay attached.
  10. Lenovo IdeaPad U310 Fan Replacement: 10 단계, 이미지 1/1
    • Remove fan by lifting up and away from device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tommie Tucker
회원 가입일: 09/28/16
270 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 1,569
