주요 콘텐츠로 건너뛰기
Lenovo IdeaPad U310 Ram Replacement
필요한 것
  1. Lenovo IdeaPad U310 Ram  Replacement, RAM: 1 단계, 이미지 1/1
    • Make sure device is turned off and disconnected from any power source before proceeding.
    • Flip the device over so the bottom panel is facing up.
    • Remove the rubber feet by pinching and pulling in an upward motion.
    • The rubber feet are missing from this photo, but will be located within the red markups.
  2. Lenovo IdeaPad U310 Ram  Replacement: 2 단계, 이미지 1/1
    • Remove the 4 screws securing the bottom panel to the device.
    • The screws are missing from this device and are not pictured. They will be located under the rubber feet within the red markups.
  3. Lenovo IdeaPad U310 Ram  Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad U310 Ram  Replacement: 3 단계, 이미지 2/2
    • Place the plastic opening tool between the bottom panel and device.
    • Pry around the device's outer edge until the bottom panel is no longer attached.
    • Lift the bottom panel up and away from device.
  4. Lenovo IdeaPad U310 Ram  Replacement: 4 단계, 이미지 1/1
    • Pry the RAM's two holding clips in an outward motion.
  5. Lenovo IdeaPad U310 Ram  Replacement: 5 단계, 이미지 1/2 Lenovo IdeaPad U310 Ram  Replacement: 5 단계, 이미지 2/2
    • Continue to pry open the clips, and slip the RAM from its housing.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Yuri Borges
회원 가입일: 09/28/16
161 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 2,494
