소개
The hard disk drive is the data storage device for your computer. If it breaks, you may choose to replace it with either another 2.5" SATA hard drive or an SSD. An SSD does not have any moving parts, is more resistant to shock, has faster read and write speeds, and runs quieter than a hard disk drive. However, SSDs are also more expensive.
필요한 것
Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
다른 한 분이 해당 안내서를 완성하였습니다.
