주요 콘텐츠로 건너뛰기
소개
RAM, or random access memory, is a form of computer data storage. RAM is used to quickly read and write data which the computer needs rapid access to. If a computer is running very slowly, it may not have enough RAM. In this scenario, the computer reads and writes to 'virtual RAM', also known as 'pagefile', on the hard drive. This is much slower.
부품
지정된 부품이 없습니다.
  1. Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
    • Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
    • These screws are 4.7mm long with a head diameter of 3.68mm.
    • The screws are attached to the panel. When unscrewing be sure to stop when you hear a click.
  2. Gently lift the back panel from the side closest to the battery and remove panel
    • Gently lift the back panel from the side closest to the battery and remove panel
  3. Push retention clips outward and then gently slide out of slot
    • Push retention clips outward and then gently slide out of slot
  4. Remove white and black wires to make room to remove the second RAM module.
    • Remove white and black wires to make room to remove the second RAM module.
  5. Just like RAM Module 1, push retention clips outward and gently slide out the RAM Module.
    • Just like RAM Module 1, push retention clips outward and gently slide out the RAM Module.
    • When re-installing RAM modules, be sure to insert them at a 45 degree angle. This is the same angle that they should pop up to after the retention clips are pushed outward.
결론
James Morizzo
회원 가입일: 2014년 09월 29일
472 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-4, Hickman Fall 2014 USF Tampa, Team 1-4, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G4
3 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 727
