주요 콘텐츠로 건너뛰기
  1. Using the metal spudger, remove all the rubber squares on the bottom of the laptop. Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
    • Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
  2. Remove the three 6 mm Phillips #1 screws  holding the panel on the laptop. Pry the panel from the laptop using your hands or the metal spudger if necessary. Pry the panel from the laptop using your hands or the metal spudger if necessary.
    • Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
    • Pry the panel from the laptop using your hands or the metal spudger if necessary.
  3. Make sure your computer is turned off.
    • Make sure your computer is turned off.
    • Lift the back panel away from you.
    • Locate the battery in the bottom right corner.
  4. Remove the three 3mm screws located on the perimeter of the battery using the Phillips #1 screwdriver.
    • Remove the three 3mm screws located on the perimeter of the battery using the Phillips #1 screwdriver.
  5. Locate the small rectangle shaped connector to the left  of your battery. Use your fingers to gently detach the white connector. Use your fingers to gently detach the white connector.
    • Locate the small rectangle shaped connector to the left of your battery.
    • Use your fingers to gently detach the white connector.
결론
Alysia Mcafee
회원 가입일: 2018년 09월 18일
107 평판
안내서 1개 작성함
University of North Texas, Team S3-G5, Raign Fall 2018 University of North Texas, Team S3-G5, Raign Fall 2018 회원
UNT-RAIGN-F18S3G5
4 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 11
전체 시간: 175
