메인 콘텐츠로 스킵하기
소개
This guide will show you how to open the bottom panel on your Lenovo IdeaPad U410 using a Phillips #1 and metal spudger.
  1. Using the metal spudger, remove all the rubber squares on the bottom of the laptop. Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
    • Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
  2. Remove the three 6 mm Phillips #1 screws  holding the panel on the laptop. Pry the panel from the laptop using your hands or the metal spudger if necessary. Pry the panel from the laptop using your hands or the metal spudger if necessary.
    • Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
    • Pry the panel from the laptop using your hands or the metal spudger if necessary.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Edric An
회원 가입일: 2018년 09월 18일
403 평판
안내서 3개 작성하였습니다
University of North Texas, Team S3-G5, Raign Fall 2018 University of North Texas, Team S3-G5, Raign Fall 2018 회원
UNT-RAIGN-F18S3G5
4 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 73
