소개
This screen replacement guide will show you how to replace your defective LCD screen on your Lenovo U410. You will need a Phillips #1 screwdriver and a metal spudger. Be careful when removing the plastic trim and connectors because you can easily break them.
필요한 것
Power off the laptop.
Using the metal spudger, gently pry off the black trim around the screen.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
