주요 콘텐츠로 건너뛰기
Lenovo IdeaPad U410 Screen Replacement
필요한 것
  1. Lenovo IdeaPad U410 Screen Replacement, Screen: 1 단계, 이미지 1/2 Lenovo IdeaPad U410 Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Make sure your laptop is turned off before disassembling.
    • Power off the laptop.
    • Using the metal spudger, gently pry off the black trim around the screen.
    • Metal spudger can be used, but using your hand will prevent the screen and the plastic border from any damage.
  2. Lenovo IdeaPad U410 Screen Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad U410 Screen Replacement: 2 단계, 이미지 2/2
    • Remove the six 3 mm Phillips #1 screws holding the screen to the laptop.
    • Ignore the "Do not touch" label on the bottom portion of the screen. It will not damage the laptop.
  3. Lenovo IdeaPad U410 Screen Replacement: 3 단계, 이미지 1/3 Lenovo IdeaPad U410 Screen Replacement: 3 단계, 이미지 2/3 Lenovo IdeaPad U410 Screen Replacement: 3 단계, 이미지 3/3
    • Lower LCD screen onto the keyboard.
    • Find the gold connector on the bottom of the LCD panel.
    • Gently grab the connector on both sides and pull the connector straight out.
    • Connector cable is very fragile. Use the least amount of force possible.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Edric An
회원 가입일: 09/18/18
433 평판
안내서 3개 작성하였습니다
University of North Texas, Team S3-G5, Raign Fall 2018 University of North Texas, Team S3-G5, Raign Fall 2018 회원
UNT-RAIGN-F18S3G5
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 21
전체 시간: 1,481
