소개
This guide will take 5 minutes and will require you to follow a prerequisite guide on how to remove the back cover. The solid state replacement will require a Phillips #1 screwdriver and a metal spudger.
필요한 것
Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
Use a Phillips #1 screwdriver to remove the 3 mm screw holding the SSD in place.
다른 한 분이 해당 안내서를 완성하였습니다.
