주요 콘텐츠로 건너뛰기
Lenovo IdeaPad U410 Solid State Drive Replacement
필요한 것
  1. Lenovo IdeaPad U410 Solid State Drive  Replacement, Bottom Cover: 1 단계, 이미지 1/2 Lenovo IdeaPad U410 Solid State Drive  Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
  2. Lenovo IdeaPad U410 Solid State Drive  Replacement: 2 단계, 이미지 1/3 Lenovo IdeaPad U410 Solid State Drive  Replacement: 2 단계, 이미지 2/3 Lenovo IdeaPad U410 Solid State Drive  Replacement: 2 단계, 이미지 3/3
    • Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
    • Pry the panel from the laptop using your hands or the metal spudger if necessary.
  3. Lenovo IdeaPad U410 Solid State Drive  Replacement, Solid State Drive: 3 단계, 이미지 1/3 Lenovo IdeaPad U410 Solid State Drive  Replacement, Solid State Drive: 3 단계, 이미지 2/3 Lenovo IdeaPad U410 Solid State Drive  Replacement, Solid State Drive: 3 단계, 이미지 3/3
    • Make sure your laptop is powered off.
    • Use a Phillips #1 screwdriver to remove the 3 mm screw holding the SSD in place.
  4. Lenovo IdeaPad U410 Solid State Drive  Replacement: 4 단계, 이미지 1/1
    • Grab the SSD and pull it out from the mSATA slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Edric An
회원 가입일: 09/18/18
433 평판
안내서 3개 작성하였습니다
University of North Texas, Team S3-G5, Raign Fall 2018 University of North Texas, Team S3-G5, Raign Fall 2018 회원
UNT-RAIGN-F18S3G5
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 17
전체 시간: 670
