주요 콘텐츠로 건너뛰기
Lenovo IdeaPad U430 Touch Battery Replacement
필요한 것
  1. Lenovo IdeaPad U430 Touch Battery Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Battery Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad U430 Touch Battery Replacement: 3 단계, 이미지 2/2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Battery Replacement, Battery: 4 단계, 이미지 1/2 Lenovo IdeaPad U430 Touch Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Remove the five 2.8 mm #1 Phillips head screws that hold down the battery pack.
  4. Lenovo IdeaPad U430 Touch Battery Replacement: 5 단계, 이미지 1/2 Lenovo IdeaPad U430 Touch Battery Replacement: 5 단계, 이미지 2/2
    • Using a combination of plastic opening tool and spudger, press in on the clips on the sides of the battery connector and push the connector out
    • When you get the connector out far enough, grab behind the connector tabs with tweezers and wiggle the connector the rest of the way out.
    • The battery connector is very tight fitting, you may need to use a metal spudger in order to get the connector out far enough.
  5. Lenovo IdeaPad U430 Touch Battery Replacement: 6 단계, 이미지 1/2 Lenovo IdeaPad U430 Touch Battery Replacement: 6 단계, 이미지 2/2
    • Once the battery is disconnected, lift up on the front of the battery and remove it from the laptop body.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Zach Cossey
회원 가입일: 09/20/16
360 평판
안내서 2개 작성하였습니다
USF Tampa, Team S2-G6, Nance Spring 2017 USF Tampa, Team S2-G6, Nance Spring 2017 회원
USFT-NANCE-S17S2G6
3 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 7,109
