주요 콘텐츠로 건너뛰기
부품
지정된 부품이 없습니다.
  1. It is important that you power off your laptop before you begin.
    • It is important that you power off your laptop before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
  2. 안드로이드 수리 키트
    A new screen or battery is one kit away.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  3. Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop. Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
결론
Patrick Ripkey
회원 가입일: 2017년 02월 28일
606 평판
안내서 5개 작성하였습니다
USF Tampa, Team S2-G6, Nance Spring 2017 USF Tampa, Team S2-G6, Nance Spring 2017 회원
USFT-NANCE-S17S2G6
3 회원들
안내서 9개 작성하였습니다
When removing the cover, be careful: There are a few (two or three?) plastic hooks that break easily in the area around the ports and the SD slot. (It's no big deal if they do break, but you can avoid it.)
Tom Janson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 28
전체 시간: 1,403
