주요 콘텐츠로 건너뛰기
Lenovo IdeaPad U430 Touch Charging Port Replacement
필요한 것
  1. Lenovo IdeaPad U430 Touch Charging Port Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Charging Port Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad U430 Touch Charging Port Replacement: 3 단계, 이미지 2/2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Charging Port Replacement, Charging Port: 4 단계, 이미지 1/2 Lenovo IdeaPad U430 Touch Charging Port Replacement, Charging Port: 4 단계, 이미지 2/2
    • Disconnect charging port from motherboard.
    • To do this, press the spudger on the center dimple and push the connector out.
  4. Lenovo IdeaPad U430 Touch Charging Port Replacement: 5 단계, 이미지 1/2 Lenovo IdeaPad U430 Touch Charging Port Replacement: 5 단계, 이미지 2/2
    • Pry the charging port out of the socket with a metal spudger.
    • It may be necessary to pry from each side.
  5. Lenovo IdeaPad U430 Touch Charging Port Replacement: 6 단계, 이미지 1/1
    • Remove charging port from laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Patrick Ripkey
회원 가입일: 02/28/17
627 평판
안내서 5개 작성하였습니다
USF Tampa, Team S2-G6, Nance Spring 2017 USF Tampa, Team S2-G6, Nance Spring 2017 회원
USFT-NANCE-S17S2G6
3 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 1,239
