소개
This guide will take you through the steps to replace a broken or missing hard drive in the Lenovo IdeaPad U430 Touch
필요한 것
Power off your computer before you begin.
Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
1. Of the first 10 screws, you did not mention that 2 of them are longer.
2. You can't lift the hard drive out without removing 4 screws (one at each corner of the drive). The plastic tool is not needed for this.
