주요 콘텐츠로 건너뛰기
Lenovo IdeaPad U430 Touch Hard Drive Replacement
필요한 것
  1. Lenovo IdeaPad U430 Touch Hard Drive Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Hard Drive Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad U430 Touch Hard Drive Replacement: 3 단계, 이미지 2/2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/1
    • Unplug the hard drive from the 22-pin cable (LZ9 HDD cable).
    • At the time of guide creation, the device did not come equipped with the hard drive.
  4. Lenovo IdeaPad U430 Touch Hard Drive Replacement: 5 단계, 이미지 1/1
    • Using the plastic opening tool, lift the hard drive from its compartment.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chris Dennis
회원 가입일: 02/20/20
190 평판
안내서 2개 작성하였습니다
댓글 한 개
1. Of the first 10 screws, you did not mention that 2 of them are longer.
2. You can't lift the hard drive out without removing 4 screws (one at each corner of the drive). The plastic tool is not needed for this.
Todd McQueen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 20
전체 시간: 1,580
