주요 콘텐츠로 건너뛰기
Lenovo IdeaPad U430 Touch Wifi Card Replacement
필요한 것
  1. Lenovo IdeaPad U430 Touch Wifi Card Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Wifi Card Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad U430 Touch Wifi Card Replacement: 3 단계, 이미지 2/2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Wifi Card Replacement, Wifi Card: 4 단계, 이미지 1/1
    • Remove the two 2.8mm screws using the Phillips #0 screwdriver.
  4. Lenovo IdeaPad U430 Touch Wifi Card Replacement: 5 단계, 이미지 1/2 Lenovo IdeaPad U430 Touch Wifi Card Replacement: 5 단계, 이미지 2/2
    • Remove the two snap cables connecting the wifi card to the rest of the computer.
  5. Lenovo IdeaPad U430 Touch Wifi Card Replacement: 6 단계, 이미지 1/1
    • Slide the Wifi card away from the Wifi card connector.
결론
Blake Hill
회원 가입일: 02/20/20
97 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 585
