주요 콘텐츠로 건너뛰기
Lenovo IdeaPad U450 Screen Replacement
필요한 것
  1. Lenovo IdeaPad U450 Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off and unplug your laptop to prevent the risk of electrocution.
    • Turn your laptop over so that the bottom is face up.
  2. Lenovo IdeaPad U450 Screen Replacement: 2 단계, 이미지 1/1
    • On the top left of the laptop there is a switch. Make sure it's pushed in the unlocked position.
  3. Lenovo IdeaPad U450 Screen Replacement: 3 단계, 이미지 1/1
    • Locate the switch collinear with the last one and move the switch to an unlocked position.
  4. Lenovo IdeaPad U450 Screen Replacement: 4 단계, 이미지 1/1
    • Remove the unlocked battery.
  5. Lenovo IdeaPad U450 Screen Replacement, Screen: 5 단계, 이미지 1/1
    • Open the laptop.
  6. Lenovo IdeaPad U450 Screen Replacement: 6 단계, 이미지 1/1
    • Remove the four 7mm phillips head screws in the corners of the screen with a Phillips #00 Screwdriver.
  7. Lenovo IdeaPad U450 Screen Replacement: 7 단계, 이미지 1/1
    • Pry the screen out of the tabs with a spudger.
  8. Lenovo IdeaPad U450 Screen Replacement: 8 단계, 이미지 1/1
    • Remove the four 7mm phillips head screws located beneath the screen.
  9. Lenovo IdeaPad U450 Screen Replacement: 9 단계, 이미지 1/1
    • Pop out the connector that links the screen to the motherboard.
  10. Lenovo IdeaPad U450 Screen Replacement: 10 단계, 이미지 1/1
    • Pop the new screen into the connector.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Rachel L Rodrigues
회원 가입일: 03/21/17
464 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S7-G1, Julie Spring 2017 UMass Dartmouth, Team S7-G1, Julie Spring 2017 회원
UMASSD-JULIE-S17S7G1
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 227
