주요 콘텐츠로 건너뛰기
Lenovo IdeaPad U530 Touch Hard Drive Replacement
필요한 것
  1. Lenovo IdeaPad U530 Touch Hard Drive Replacement, Battery: 1 단계, 이미지 1/3 Lenovo IdeaPad U530 Touch Hard Drive Replacement, Battery: 1 단계, 이미지 2/3 Lenovo IdeaPad U530 Touch Hard Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the back panel by removing all screws. Use a PH000 screwdriver head.
    • Make sure to also remove the hinge screws.
  2. Lenovo IdeaPad U530 Touch Hard Drive Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad U530 Touch Hard Drive Replacement: 2 단계, 이미지 2/2
    • To remove the panel, use a plastic opening tool to prevent any damage.
  3. Lenovo IdeaPad U530 Touch Hard Drive Replacement: 3 단계, 이미지 1/1
    • Locate and assess the battery. Pictured in the upper right area of the computer.
  4. Lenovo IdeaPad U530 Touch Hard Drive Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad U530 Touch Hard Drive Replacement: 4 단계, 이미지 2/2
    • Locate and remove all screws attaching the battery to the hull of the computer. It is recommended that you use a JIS #1 screwdriver head for this task.
    • Be careful to keep track of all removed screws.
  5. Lenovo IdeaPad U530 Touch Hard Drive Replacement: 5 단계, 이미지 1/1
    • Detach the connection from the battery to the motherboard. This is the only connection that needs to be disconnected for the battery.
    • To remove the connection, please pull firmly, as it well secured.
  6. Lenovo IdeaPad U530 Touch Hard Drive Replacement: 6 단계, 이미지 1/1
    • Simply lift the battery out of the computer, and acquire a replacement.
  7. Lenovo IdeaPad U530 Touch Hard Drive Replacement, Hard Drive: 7 단계, 이미지 1/3 Lenovo IdeaPad U530 Touch Hard Drive Replacement, Hard Drive: 7 단계, 이미지 2/3 Lenovo IdeaPad U530 Touch Hard Drive Replacement, Hard Drive: 7 단계, 이미지 3/3
    • Remove two 3 mm screws connecting the hard drive to the computer base using a JIS #1 screwdriver.
    • Detach the connection from the hard drive to the motherboard.
    • Remove the hard drive from the laptop.
결론
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 611
