주요 콘텐츠로 건너뛰기
Lenovo IdeaPad U530 Touch Network Adapter Replacement
필요한 것
  1. Lenovo IdeaPad U530 Touch Network Adapter Replacement, Network Adapter: 1 단계, 이미지 1/3 Lenovo IdeaPad U530 Touch Network Adapter Replacement, Network Adapter: 1 단계, 이미지 2/3 Lenovo IdeaPad U530 Touch Network Adapter Replacement, Network Adapter: 1 단계, 이미지 3/3
    • Remove all of the screws on the back panel with a Phillips #000 screwdriver.
    • Turn over the device and remove the two screws on the outside of the hinges.
  2. Lenovo IdeaPad U530 Touch Network Adapter Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad U530 Touch Network Adapter Replacement: 2 단계, 이미지 2/2
    • Use a pry tool or iFixIt Opening tool to separate the back panel from the device.
    • Lift the back panel straight up to remove.
  3. Lenovo IdeaPad U530 Touch Network Adapter Replacement: 3 단계, 이미지 1/3 Lenovo IdeaPad U530 Touch Network Adapter Replacement: 3 단계, 이미지 2/3 Lenovo IdeaPad U530 Touch Network Adapter Replacement: 3 단계, 이미지 3/3
    • Remove the black and white wires that attach the fan to the network adapter.
  4. Lenovo IdeaPad U530 Touch Network Adapter Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad U530 Touch Network Adapter Replacement: 4 단계, 이미지 2/2
    • Remove the two screws attaching the network adapter to the motherboard.
    • Remove the network adapter by sliding it down out of its connector.
결론
Rebekah Harmon
회원 가입일: 01/23/18
108 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 407
