주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Y400 Battery Replacement
  1. Lenovo IdeaPad Y400 Battery Replacement, Battery: 1 단계, 이미지 1/3 Lenovo IdeaPad Y400 Battery Replacement, Battery: 1 단계, 이미지 2/3 Lenovo IdeaPad Y400 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure the laptop is upside down, then turn the laptop so that the battery is facing you. Now that the battery is facing you, there will be two locks, one on the left and one on the right.
    • Slide the lock to the right until you can hear a "click". Once you hear this click, you should be able to see the color red.
  2. Lenovo IdeaPad Y400 Battery Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad Y400 Battery Replacement: 2 단계, 이미지 2/2
    • Unlike the first lock, the left lock does not stay in place. You will need to hold it in place as you take the battery out.
    • Slide the second (left) lock to the left and hold it there.
  3. Lenovo IdeaPad Y400 Battery Replacement: 3 단계, 이미지 1/1
    • Gently pull the battery out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Rachel Simmons
회원 가입일: 09/26/18
603 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 189
