주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Y410p Keyboard Replacement
필요한 것
  1. Lenovo IdeaPad Y410p Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Keyboard Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad Y410p Keyboard Replacement: 2 단계, 이미지 2/2
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Keyboard Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad Y410p Keyboard Replacement: 3 단계, 이미지 2/2
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Keyboard Replacement, Keyboard: 4 단계, 이미지 1/2 Lenovo IdeaPad Y410p Keyboard Replacement, Keyboard: 4 단계, 이미지 2/2
    • Power off your laptop.
    • Use a metal spudger to loosen the frame of the keyboard by running it under the edges of the keyboard as shown.
    • After loosening the keyboard frame, you should be able to gently lift up the keyboard.
  5. Lenovo IdeaPad Y410p Keyboard Replacement: 5 단계, 이미지 1/3 Lenovo IdeaPad Y410p Keyboard Replacement: 5 단계, 이미지 2/3 Lenovo IdeaPad Y410p Keyboard Replacement: 5 단계, 이미지 3/3
    • Be careful when lifting the keyboard so that you do not damage the ribbon cable connector.
    • Detach the ribbon cables from the latches shown.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nick Torres
회원 가입일: 09/18/18
580 평판
안내서 5개 작성하였습니다
University of North Texas, Team S3-G6, Raign Fall 2018 University of North Texas, Team S3-G6, Raign Fall 2018 회원
UNT-RAIGN-F18S3G6
4 회원들
안내서 5개 작성하였습니다
댓글 2개
Terrible guide - completely fails to point out the two screws that hold the keyboard down underneath the bottom casing. Bent my keyboard thanks to this.
Dragon - 답글
Awful guide. Wish I'd seen the other comment before I also ruined my keyboard. Thought it popped out, but there's 2 screws under the bottom case that hold it (remove!) … bent the keyboard frame and ripped the screw tabs off. Was just trying to clean it. Now it needs total replacement.
How is this article reportable?
Nateb - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 993
