주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Y410p Keyboard Replacement
필요한 것
  1. Lenovo IdeaPad Y410p Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Lenovo IdeaPad Y410p Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Lenovo IdeaPad Y410p Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Keyboard Replacement, Keyboard: 4 단계, 이미지 2개 중 1개 Lenovo IdeaPad Y410p Keyboard Replacement, Keyboard: 4 단계, 이미지 2개 중 2개
    • Power off your laptop.
    • Use a metal spudger to loosen the frame of the keyboard by running it under the edges of the keyboard as shown.
    • After loosening the keyboard frame, you should be able to gently lift up the keyboard.
  5. Lenovo IdeaPad Y410p Keyboard Replacement: 5 단계, 이미지 3개 중 1개 Lenovo IdeaPad Y410p Keyboard Replacement: 5 단계, 이미지 3개 중 2개 Lenovo IdeaPad Y410p Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Be careful when lifting the keyboard so that you do not damage the ribbon cable connector.
    • Detach the ribbon cables from the latches shown.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Nick Torres
회원 가입일: 09/18/18
580 평판
안내서 5개를 작성함
2가이드 댓글
Terrible guide - completely fails to point out the two screws that hold the keyboard down underneath the bottom casing. Bent my keyboard thanks to this.
Dragon - 답글
Awful guide. Wish I'd seen the other comment before I also ruined my keyboard. Thought it popped out, but there's 2 screws under the bottom case that hold it (remove!) … bent the keyboard frame and ripped the screw tabs off. Was just trying to clean it. Now it needs total replacement.
How is this article reportable?
Nateb - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 12
전체 시간: 1,171
