주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Y410p Ram Replacement
필요한 것
  1. Lenovo IdeaPad Y410p Ram Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Ram Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad Y410p Ram Replacement: 2 단계, 이미지 2/2
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Ram Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad Y410p Ram Replacement: 3 단계, 이미지 2/2
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Ram Replacement, Ram: 4 단계, 이미지 1/3 Lenovo IdeaPad Y410p Ram Replacement, Ram: 4 단계, 이미지 2/3 Lenovo IdeaPad Y410p Ram Replacement, Ram: 4 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver remove the eight 8mm screws that fasten the bottom cover.
    • Lift the bottom cover off using a metal spudger and set it aside.
  5. Lenovo IdeaPad Y410p Ram Replacement: 5 단계, 이미지 1/2 Lenovo IdeaPad Y410p Ram Replacement: 5 단계, 이미지 2/2
    • Simultaneously pull apart both clips that are holding the RAM module down.
    • When the RAM module is released carefully pull it out.
  6. Lenovo IdeaPad Y410p Ram Replacement: 6 단계, 이미지 1/2 Lenovo IdeaPad Y410p Ram Replacement: 6 단계, 이미지 2/2
    • There is a second ram module under the first one.
    • Repeat Step 5 with lower Ram module.
결론
Nick Torres
회원 가입일: 09/18/18
580 평판
안내서 5개 작성하였습니다
University of North Texas, Team S3-G6, Raign Fall 2018 University of North Texas, Team S3-G6, Raign Fall 2018 회원
UNT-RAIGN-F18S3G6
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 19
전체 시간: 869
