주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Y410p Screen Replacement
필요한 것
  1. Lenovo IdeaPad Y410p Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Screen Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad Y410p Screen Replacement: 2 단계, 이미지 2/2
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Screen Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad Y410p Screen Replacement: 3 단계, 이미지 2/2
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Screen Replacement, Screen: 4 단계, 이미지 1/2 Lenovo IdeaPad Y410p Screen Replacement, Screen: 4 단계, 이미지 2/2
    • Using the metal spudger, pry the screen cover off from all sides.
    • Carefully lift the screen cover up and outwards.
    • Place the screen cover aside.
  5. Lenovo IdeaPad Y410p Screen Replacement: 5 단계, 이미지 1/3 Lenovo IdeaPad Y410p Screen Replacement: 5 단계, 이미지 2/3 Lenovo IdeaPad Y410p Screen Replacement: 5 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the four 8mm screws from each corner of the screen.
    • Carefully lift the screen up and place it face down on the keyboard.
    • A thick cord connects the bottom of the screen to the computer. Do not tug or remove this cord from the computer.
  6. Lenovo IdeaPad Y410p Screen Replacement: 6 단계, 이미지 1/2 Lenovo IdeaPad Y410p Screen Replacement: 6 단계, 이미지 2/2
    • Remove the adhesive tape from the small rectangular connector at the bottom of the screen.
    • Carefully pull the wire connector from the screen connector.
    • Remove the screen.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nick Torres
회원 가입일: 09/18/18
580 평판
안내서 5개 작성하였습니다
University of North Texas, Team S3-G6, Raign Fall 2018 University of North Texas, Team S3-G6, Raign Fall 2018 회원
UNT-RAIGN-F18S3G6
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 6
전체 시간: 366
