주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Y500 Motherboard Replacement
필요한 것
  1. Lenovo IdeaPad Y500 Motherboard Replacement, Battery: 1 단계, 이미지 1/3 Lenovo IdeaPad Y500 Motherboard Replacement, Battery: 1 단계, 이미지 2/3 Lenovo IdeaPad Y500 Motherboard Replacement, Battery: 1 단계, 이미지 3/3
    • Slide the lock on the right side until you hear a click. Once you hear a click , you should see the color red.
  2. Lenovo IdeaPad Y500 Motherboard Replacement: 2 단계, 이미지 1/1
    • Unlike the first lock, this lock is spring loaded and must be held in place when used.
    • Slide the lock to the left (in the direction of the arrow below the lock) and hold in place.
  3. Lenovo IdeaPad Y500 Motherboard Replacement: 3 단계, 이미지 1/1
    • Gently pull battery away from the computer while holding open the lock.
  4. Lenovo IdeaPad Y500 Motherboard Replacement, Keyboard: 4 단계, 이미지 1/3 Lenovo IdeaPad Y500 Motherboard Replacement, Keyboard: 4 단계, 이미지 2/3 Lenovo IdeaPad Y500 Motherboard Replacement, Keyboard: 4 단계, 이미지 3/3
    • Unlock the battery latch by pulling it up.
    • It should reveal red underneath when it's unlocked.
  5. Lenovo IdeaPad Y500 Motherboard Replacement: 5 단계, 이미지 1/3 Lenovo IdeaPad Y500 Motherboard Replacement: 5 단계, 이미지 2/3 Lenovo IdeaPad Y500 Motherboard Replacement: 5 단계, 이미지 3/3
    • Push the latch down and then hold in position.
    • Pull the optical drive out.
  6. Lenovo IdeaPad Y500 Motherboard Replacement: 6 단계, 이미지 1/3 Lenovo IdeaPad Y500 Motherboard Replacement: 6 단계, 이미지 2/3 Lenovo IdeaPad Y500 Motherboard Replacement: 6 단계, 이미지 3/3
    • Remove nine screws with a Phillips #1 screwdriver.
  7. Lenovo IdeaPad Y500 Motherboard Replacement: 7 단계, 이미지 1/3 Lenovo IdeaPad Y500 Motherboard Replacement: 7 단계, 이미지 2/3 Lenovo IdeaPad Y500 Motherboard Replacement: 7 단계, 이미지 3/3
    • Pull up on the loosened cover to remove.
    • Remove two screws with a Phillips #1 screwdriver.
  8. Lenovo IdeaPad Y500 Motherboard Replacement: 8 단계, 이미지 1/3 Lenovo IdeaPad Y500 Motherboard Replacement: 8 단계, 이미지 2/3 Lenovo IdeaPad Y500 Motherboard Replacement: 8 단계, 이미지 3/3
    • Pull the tab straight to the left until part releases.
    • Lift up the part to remove completely.
  9. Lenovo IdeaPad Y500 Motherboard Replacement: 9 단계, 이미지 1/3 Lenovo IdeaPad Y500 Motherboard Replacement: 9 단계, 이미지 2/3 Lenovo IdeaPad Y500 Motherboard Replacement: 9 단계, 이미지 3/3
    • To release the DIMM, pull the tabs on either side away from each other simultaneously.
    • The DIMM will pop out on its own.
  10. Lenovo IdeaPad Y500 Motherboard Replacement: 10 단계, 이미지 1/3 Lenovo IdeaPad Y500 Motherboard Replacement: 10 단계, 이미지 2/3 Lenovo IdeaPad Y500 Motherboard Replacement: 10 단계, 이미지 3/3
    • To disconnect the Wi-Fi cables, use a spudger to gently push up under them.
    • Wi-Fi cables are delicate.
  11. Lenovo IdeaPad Y500 Motherboard Replacement: 11 단계, 이미지 1/3 Lenovo IdeaPad Y500 Motherboard Replacement: 11 단계, 이미지 2/3 Lenovo IdeaPad Y500 Motherboard Replacement: 11 단계, 이미지 3/3
    • Using a Phillips #1 screwdriver, remove the two screws.
    • Once screws are out, the card will just pop out.
  12. Lenovo IdeaPad Y500 Motherboard Replacement: 12 단계, 이미지 1/1
    • Remove three screws using a Phillips #1 screwdriver.
  13. Lenovo IdeaPad Y500 Motherboard Replacement: 13 단계, 이미지 1/3 Lenovo IdeaPad Y500 Motherboard Replacement: 13 단계, 이미지 2/3 Lenovo IdeaPad Y500 Motherboard Replacement: 13 단계, 이미지 3/3
    • With the laptop upside down, open slightly.
    • To remove the keyboard, push the back of the keyboard forward with your thumb while pulling away from the laptop on the other side.
    • You will not be able to pull the keyboard completely away. The cables are still connected to the laptop.
  14. Lenovo IdeaPad Y500 Motherboard Replacement: 14 단계, 이미지 1/3 Lenovo IdeaPad Y500 Motherboard Replacement: 14 단계, 이미지 2/3 Lenovo IdeaPad Y500 Motherboard Replacement: 14 단계, 이미지 3/3
    • To release the cables, use the spudger to push both ends on the side of the cable.
    • Gently pull the cables up to disconnect.
  15. Lenovo IdeaPad Y500 Motherboard Replacement: 15 단계, 이미지 1/2 Lenovo IdeaPad Y500 Motherboard Replacement: 15 단계, 이미지 2/2
    • Pull the keyboard up and away from the laptop to remove it.
  16. Lenovo IdeaPad Y500 Motherboard Replacement, Touchpad: 16 단계, 이미지 1/2 Lenovo IdeaPad Y500 Motherboard Replacement, Touchpad: 16 단계, 이미지 2/2
    • Remove a total of 8 screws.
    • Red circles are m2.5 x 10 mm flathead screws.
    • Orange circles m2 x 3mm flathead screws.
    • Yellow circle is m2.5 x 4mm flathead screw.
  17. Lenovo IdeaPad Y500 Motherboard Replacement: 17 단계, 이미지 1/3 Lenovo IdeaPad Y500 Motherboard Replacement: 17 단계, 이미지 2/3 Lenovo IdeaPad Y500 Motherboard Replacement: 17 단계, 이미지 3/3
    • Flip up black tabs at the ends of each cable.
    • With fingers, gently remove the cables underneath from their ports.
  18. Lenovo IdeaPad Y500 Motherboard Replacement: 18 단계, 이미지 1/3 Lenovo IdeaPad Y500 Motherboard Replacement: 18 단계, 이미지 2/3 Lenovo IdeaPad Y500 Motherboard Replacement: 18 단계, 이미지 3/3
    • By unlatching the sides and pulling up, remove the top case from the device.
    • Casing is fragile, be careful not to twist when pulling up.
  19. Lenovo IdeaPad Y500 Motherboard Replacement, Motherboard: 19 단계, 이미지 1/3 Lenovo IdeaPad Y500 Motherboard Replacement, Motherboard: 19 단계, 이미지 2/3 Lenovo IdeaPad Y500 Motherboard Replacement, Motherboard: 19 단계, 이미지 3/3
    • Peel up the black tab and remove the tape completely.
    • Remove the cable revealed underneath while pulling up the tape.
    • When reassembled, you will have to stick the tape back down in its original location in order to reinsert the cable.
  20. Lenovo IdeaPad Y500 Motherboard Replacement: 20 단계, 이미지 1/3 Lenovo IdeaPad Y500 Motherboard Replacement: 20 단계, 이미지 2/3 Lenovo IdeaPad Y500 Motherboard Replacement: 20 단계, 이미지 3/3
    • Flip the laptop back over.
    • Gently pull the cable free by pulling up.
  21. Lenovo IdeaPad Y500 Motherboard Replacement: 21 단계, 이미지 1/3 Lenovo IdeaPad Y500 Motherboard Replacement: 21 단계, 이미지 2/3 Lenovo IdeaPad Y500 Motherboard Replacement: 21 단계, 이미지 3/3
    • Peel back the black tape.
    • Gently pull out both cables revealed underneath from their sockets.
    • When reassembling, you will have to paste the tape back over the cables again.
  22. Lenovo IdeaPad Y500 Motherboard Replacement: 22 단계, 이미지 1/3 Lenovo IdeaPad Y500 Motherboard Replacement: 22 단계, 이미지 2/3 Lenovo IdeaPad Y500 Motherboard Replacement: 22 단계, 이미지 3/3
    • By gently pulling up, remove the final cable.
  23. Lenovo IdeaPad Y500 Motherboard Replacement: 23 단계, 이미지 1/2 Lenovo IdeaPad Y500 Motherboard Replacement: 23 단계, 이미지 2/2
    • Pull motherboard down, away from the case, while lifting the base of the case up.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Tatum Hennige
회원 가입일: 04/22/19
687 평판
안내서 4개 작성하였습니다
UW Tacoma, Team S1-G2, Cardinal Spring 2019 UW Tacoma, Team S1-G2, Cardinal Spring 2019 회원
UWT-CARDINAL-S19S1G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 20
전체 시간: 2,306
