주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Y510P Key Replacement
필요한 것
  1. Lenovo IdeaPad Y510P Key Replacement, Key: 1 단계, 이미지 1/1
    • Locate the key that is behaving abnormally.
    • Gently insert a spudger underneath the key cap.
    • Be sure to use a tip that is not too thick, or apply too much pressure as you can damage the mounting point that attaches the key cap to the hinge.
  2. Lenovo IdeaPad Y510P Key Replacement: 2 단계, 이미지 1/1
    • Gently lift the key out of the hinge socket by using a prying motion. The key cap should lift out easily.
    • If the key does not lift out easily, try inserting your prying tool closer to the center of the keycap before prying.
  3. Lenovo IdeaPad Y510P Key Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad Y510P Key Replacement: 3 단계, 이미지 2/2
    • Using a similar motion to the previous step, insert the prying tool under the white key hinge and pry.
    • At this point you can now replace the key hinge with a new part, or decompress the hinge and place it in the same position it was originally in.
  4. Lenovo IdeaPad Y510P Key Replacement: 4 단계, 이미지 1/1
    • You may now place your key cap back onto the hinge by guiding the center of the key onto the center of the hinge.
    • You were successful with the repair if you press the key and it returns to its initial position immediately.
결론
If you adjusted the key hinge, rather than replacing it, test the key to ensure the behavior was fixed. If the key still sticks on press, repeat the guide and replace the hinge as compared to adjusting it.
다른 2명이 해당 안내서를 완성하였습니다.
Jose
회원 가입일: 09/21/18
138 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 27
전체 시간: 754
