주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Y580-2099 Keyboard Replacement
필요한 것
  1. Lenovo IdeaPad Y580-2099 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Slide out both locks for the battery, located on the back of the device.
  2. Lenovo IdeaPad Y580-2099 Keyboard Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad Y580-2099 Keyboard Replacement: 2 단계, 이미지 2/2
    • Remove the battery.
  3. Lenovo IdeaPad Y580-2099 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/2 Lenovo IdeaPad Y580-2099 Keyboard Replacement, Keyboard: 3 단계, 이미지 2/2
    • Unscrew the 2 screws on the bottom of the device.
    • Slide the back panel out.
  4. Lenovo IdeaPad Y580-2099 Keyboard Replacement: 4 단계, 이미지 1/1
    • Unscrew the 3 "keyboard" detected screws.
  5. Lenovo IdeaPad Y580-2099 Keyboard Replacement: 5 단계, 이미지 1/2 Lenovo IdeaPad Y580-2099 Keyboard Replacement: 5 단계, 이미지 2/2
    • Flip the laptop over and open up.
    • Then pry up the whole keyboard using the spudger.
    • Make sure to use a plastic spudger. You could damage the device using anything else.
    • Make sure not to take the frame that goes around the keys off. This part is not removable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lauren
회원 가입일: 09/25/17
481 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 1,538
