주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Y580-2099 Speaker Replacement
필요한 것
  1. Lenovo IdeaPad Y580-2099 Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Slide out both locks for the battery, located on the back of the device.
  2. Lenovo IdeaPad Y580-2099 Speaker Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad Y580-2099 Speaker Replacement: 2 단계, 이미지 2/2
    • Remove the battery.
  3. Lenovo IdeaPad Y580-2099 Speaker Replacement, Keyboard: 3 단계, 이미지 1/2 Lenovo IdeaPad Y580-2099 Speaker Replacement, Keyboard: 3 단계, 이미지 2/2
    • Unscrew the 2 screws on the bottom of the device.
    • Slide the back panel out.
  4. Lenovo IdeaPad Y580-2099 Speaker Replacement: 4 단계, 이미지 1/1
    • Unscrew the 3 "keyboard" detected screws.
  5. Lenovo IdeaPad Y580-2099 Speaker Replacement: 5 단계, 이미지 1/2 Lenovo IdeaPad Y580-2099 Speaker Replacement: 5 단계, 이미지 2/2
    • Flip the laptop over and open up.
    • Then pry up the whole keyboard using the spudger.
    • Make sure to use a plastic spudger. You could damage the device using anything else.
    • Make sure not to take the frame that goes around the keys off. This part is not removable.
  6. Lenovo IdeaPad Y580-2099 Speaker Replacement, Motherboard: 6 단계, 이미지 1/3 Lenovo IdeaPad Y580-2099 Speaker Replacement, Motherboard: 6 단계, 이미지 2/3 Lenovo IdeaPad Y580-2099 Speaker Replacement, Motherboard: 6 단계, 이미지 3/3
    • Flip laptop back over and unscrew the disc drive screw.
    • Remove the disc drive.
    • Unscrew all of the screws on the back of the device.
  7. Lenovo IdeaPad Y580-2099 Speaker Replacement: 7 단계, 이미지 1/3 Lenovo IdeaPad Y580-2099 Speaker Replacement: 7 단계, 이미지 2/3 Lenovo IdeaPad Y580-2099 Speaker Replacement: 7 단계, 이미지 3/3
    • Flip the device over.
    • Unplug the two wires, as shown in the images.
    • Lift up on the keyboard bezel.
    • The bezel should come up easy, if not go back and make sure all screws have been removed.
  8. Lenovo IdeaPad Y580-2099 Speaker Replacement: 8 단계, 이미지 1/2 Lenovo IdeaPad Y580-2099 Speaker Replacement: 8 단계, 이미지 2/2
    • Unscrew the screws on the motherboard.
    • Disconnect the three connectors the two black and one white.
  9. Lenovo IdeaPad Y580-2099 Speaker Replacement: 9 단계, 이미지 1/1
    • Carefully lift up the motherboard.
    • Unplug the wires underneath the motherboard.
    • Be careful not to rip the wires underneath the motherboard while lifting it up.
  10. Lenovo IdeaPad Y580-2099 Speaker Replacement, Speakers: 10 단계, 이미지 1/2 Lenovo IdeaPad Y580-2099 Speaker Replacement, Speakers: 10 단계, 이미지 2/2
    • Unscrew the two screws in each of the corners of the speakers.
    • Remove the speakers.
결론
Lauren
회원 가입일: 09/25/17
481 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 14
전체 시간: 1,472
