주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement
필요한 것
  1. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 1/1
    • Make sure the laptop is powered off and disconnected from the charger.
    • Flip the laptop upside down so that the bottom faces up.
  2. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: 2 단계, 이미지 1/1
    • Place your thumbs on each side of the laptop and slide the tabs into the unlock position.
  3. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: 3 단계, 이미지 1/1
    • Once tabs are in the unlock position, carefully slide the battery out of the compartment.
  4. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: 4 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to unscrew and remove the two 8 mm screws (highlighted in red) that secure the back panel in place.
  5. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: 5 단계, 이미지 1/1
    • Gently slide & pull the panel off the device.
  6. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: 6 단계, 이미지 1/2 Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: 6 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws that secure the Wi-Fi card in place.
  7. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: 7 단계, 이미지 1/1
    • Gently unplug the two coaxial antenna cables clasped to the Wi-Fi card.
  8. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: 8 단계, 이미지 1/1
    • Gently remove the old Wi-Fi card from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jeryn Fast
회원 가입일: 04/12/22
421 평판
안내서 3개 작성하였습니다
IUPUI, Team 1-1, Beck Spring 2022 IUPUI, Team 1-1, Beck Spring 2022 회원
IUPUI-BECK-S22S1G1
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 12
전체 시간: 301
