주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Y700-15ACZ Cooling Fan Replacement
필요한 것
  1. Lenovo IdeaPad Y700-15ACZ Cooling Fan Replacement, Cooling Fan: 1 단계, 이미지 1/2 Lenovo IdeaPad Y700-15ACZ Cooling Fan Replacement, Cooling Fan: 1 단계, 이미지 2/2
    • Flip your laptop so that the bottom of it is facing you.
    • Use a Phillips #00 screwdriver to remove the following screws from the bottom cover:
    • Eight 5.4 mm screws.
    • One 5.6 mm screws.
    • Two 15.4 mm screws.
    • Remove the back plane.
  2. Lenovo IdeaPad Y700-15ACZ Cooling Fan Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad Y700-15ACZ Cooling Fan Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the three 3.9 mm screws.
    • Use a Phillips #00 screwdriver to remove the single 5.6 mm screw between the two fans.
    • This tutorial is describing how to replace both fans, if you need to replace one fan, you don't need to remove both.
  3. Lenovo IdeaPad Y700-15ACZ Cooling Fan Replacement: 3 단계, 이미지 1/1
    • To disconnect the cable, pull it straight out of the connector.
    • To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable. If you can, apply the force to the plastic reinforcement rather than the cable itself.
  4. Lenovo IdeaPad Y700-15ACZ Cooling Fan Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad Y700-15ACZ Cooling Fan Replacement: 4 단계, 이미지 2/2
    • Remove the fan(s) from the laptop after finishing Step 3.
결론
To reassemble your device, follow these instructions in reverse order. To ensure that every component is perfectly aligned and firmly secured, careful attention to detail must be made during the reassembly procedure. Inaccurately following the instructions may cause harm to the device, which might affect its durability and operation. Therefore, it is crucial to carefully follow the instructions provided in order to complete the reassembly in a successful and secure manner.
Antwan Khoury
회원 가입일: 03/28/23
109 평판
안내서 1개 작성함
IUPUI, Team 3-1, Harley Spring 2023 IUPUI, Team 3-1, Harley Spring 2023 회원
IUPUI-HARLEY-S23S3G1
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 16
전체 시간: 318
