주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Y700-15ACZ Display Replacement
필요한 것
  1. Lenovo IdeaPad Y700-15ACZ Display Replacement, Display: 1 단계, 이미지 1/2 Lenovo IdeaPad Y700-15ACZ Display Replacement, Display: 1 단계, 이미지 2/2
    • Remove the border around the screen using a plastic opening tool.
    • When removing the border be careful, the plastic connectors can sometimes break under little amounts of pressure
  2. Lenovo IdeaPad Y700-15ACZ Display Replacement: 2 단계, 이미지 1/3 Lenovo IdeaPad Y700-15ACZ Display Replacement: 2 단계, 이미지 2/3 Lenovo IdeaPad Y700-15ACZ Display Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the four screws that secure the display (one screw at each corner).
  3. Lenovo IdeaPad Y700-15ACZ Display Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad Y700-15ACZ Display Replacement: 3 단계, 이미지 2/2
    • Before you remove or rotate the display, remove the cable connected to the display from the constraints.
  4. Lenovo IdeaPad Y700-15ACZ Display Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad Y700-15ACZ Display Replacement: 4 단계, 이미지 2/2
    • Rotate the display face down.
    • From the sticker carefully peel down and remove the connection from the display.
    • Attach the ribbon to the new display.
결론
Repeat steps backward to put the computer back together. After you have completed the reassembly, make sure to test the new display by powering on the device.
Colin Burke
회원 가입일: 03/28/23
109 평판
안내서 1개 작성함
IUPUI, Team 3-1, Harley Spring 2023 IUPUI, Team 3-1, Harley Spring 2023 회원
IUPUI-HARLEY-S23S3G1
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 188
