주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Y700-15ACZ Motherboard Replacement
필요한 것
  1. Lenovo IdeaPad Y700-15ACZ Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Lenovo IdeaPad Y700-15ACZ Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Flip the laptop upside down so that the bottom is facing up.
    • Using the #0 Phillips screwdriver, unscrew the eleven Phillips #0 screws (two 1.5 mm screws, one 0.3 mm screw, and eight 0.5 mm screws) that attach the cover to the laptop.
  2. Lenovo IdeaPad Y700-15ACZ Motherboard Replacement: 2 단계, 이미지 1/1
    • After removing the eleven Phillips #0 screws (two 1.5 mm screws, one 0.3 mm screw, and eight 0.5 mm screws), use the Jimmy to pop up the cover and remove it from the laptop.
  3. Lenovo IdeaPad Y700-15ACZ Motherboard Replacement: 3 단계, 이미지 1/3 Lenovo IdeaPad Y700-15ACZ Motherboard Replacement: 3 단계, 이미지 2/3 Lenovo IdeaPad Y700-15ACZ Motherboard Replacement: 3 단계, 이미지 3/3
    • Unscrew the 16 Phillips #0 screws and 1 Philips #00 screw ( 0.5 mm screws, one 1 mm screw) from the motherboard, the fan, and the speaker to remove and replace the motherboard.
결론
Kevin
회원 가입일: 09/28/22
351 평판
안내서 3개 작성하였습니다
CSU Los Angeles, Team 6-6, Adachi Fall 2022 CSU Los Angeles, Team 6-6, Adachi Fall 2022 회원
CSULA-ADACHI-F22S6G6
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 238
