소개
If your Lenovo Ideapad Y700-15ACZ does not turn on no matter what you do the mother board needs to be replaced. Follow this guide to replace the motherboard. First check if a laptop restart can solve any issues. If not then continue with this guide.
The motherboard is the backbone of the laptop so replacing it would preserve your laptop.
필요한 것
Flip the laptop upside down so that the bottom is facing up.
Using the #0 Phillips screwdriver, unscrew the eleven Phillips #0 screws (two 1.5 mm screws, one 0.3 mm screw, and eight 0.5 mm screws) that attach the cover to the laptop.
